The Process Watch includes a shortcut for each of the filters. You can use the following procedure to add filters to the Process Watch.
The selected object is added as a shortcut in the Process Watch.
To view the object instance for the selected filters, click the Operations tab and expand the Process Watch palette. You can select the new shortcut from the location you created the shortcut in. Corresponding instances are displayed for the process object, depending on the filters that you specified.
