Running, Testing, and Debugging Processes › The Operations Page › Process Watch Objects › Create a New Process Watch Object
Define a new Process Watch object in the Library Browser and monitor the status of each object that it includes on the Operations page.
Note: To set rights and perform other object tasks, the best practice is to organize the objects in folders. Do not create objects at the root level because you cannot manage such objects as a group.
- Click the Library tab.
- In the Library folders pane
- Select an orchestrator in the design or production environment.
- Select a folder.
- In the toolbar, click New and select Process Watch.
A new process watch object appears in the selected folder.
- In the Name field, enter a name for the process watch.
- Double-click the new process watch.
The Process Watch opens in a browser window.
- In the left pane
- Select the domain, environment, orchestrator, touchpoint, host group, and folder for the object you want to add to the process watch.
- Select the object that you want to include in the process watch.
- In the toolbar, click Add New.
The selected object is added to the process watch. The name, object type, reference path, mode, and description of the selected object appears.
- If you added a process, select one or more States that you want to display in process watch, for example, queued, suspended, and blocked.
- Click Save.
