The Reset Operators command resets selected operators in a suspended process to their initial states as if they had not been executed. This command is typically used to allow operators in an instance of a process to run again without resetting the entire process. You can modify the operators with different parameter settings, or modify the process in other ways.
If necessary, suspend execution of a running instance.
The operators are reset.
Any Loop operators are reset as follows:
After the reset, the Loop operator will restart from the first iteration.
