You can use the Disable Operators command to disable an operator and temporarily disable part of a process without otherwise modifying the process. Disabling an operator stops execution of the operator and all subsequent operators in a branch of a process. An operator is inaccessible to a process when every path to it from any Start operator passes through a deactivated operator. The Disable Operators command is available when editing either the definition object for a process or an instance of a process.
To disable an operator in a process
Note: For a running instance of a process, suspend execution before proceeding to the next step of the procedure.
The disabled symbol appears next to the operator.
Note: To enable disabled operators, select one or more disabled operators, and click Enable Operators on the toolbar.
You can also deactivate an entire branch by right-clicking a link and selecting Disable Link from the menu.
