You can open an instance of an object from the Content Packages window Details pane. Opening an object lets you closely monitor the object instance while the instance runs. Your changes to an object instance affect only how that instance runs; the changes do not modify the object definition in the Library.
Note: A CA Process Automation user must have sufficient permissions to view or edit an object in the Content Package window.
You can perform the following actions to an object in a content package:
