Library Browser › Working with Objects and Folders › Edit an Object › Specify the Folder Release
A content designer can provide release information for a folder. The Release tab in the folder properties provides the release version of the folder. Specifying the release version for a folder is required to export the folder as a content package. Adding information that describes the folder content can help the content package consumer when the content is imported to a new environment.
- Click the Library tab.
- Right-click the folder on the right pane of the Library, and then select Properties.
- On the Properties pane, click the Release tab to display the folder properties.
- Click the ReleaseVersion attribute Value field.
- On the Value window, enter the folder Release Version, and then click OK.
Note: You cannot delete or edit the ReleaseVersion attribute, but you can insert the appropriate release version in the Value column.
- Click Save.
- Click Add Property or Remove Property to define or remove more folder properties.
For example, you can add the following information in the Release tab:
- Owner who created the content package.
- Users who can use the content package objects after it is imported to a new environment.
- Support information.
- Online help (URL to online help).
