Library Browser › Working with Objects and Folders › Edit an Object › Specify ROI Properties
When you set the Return on Investment (ROI) properties for a process object, the values you enter appear in the process instances dataset.
- Click the Library tab.
- Select a folder, right-click a process object, and then select Properties.
- On the Properties pane, click the ROI tab.
- Select the Enable ROI check box.
- Enter the following values:
- In the Manual Labor Time field, enter the total staff time (in hours and minutes) required to trigger multiple process operations manually.
- In the Manual Process Elapsed Time field, enter the total staff time (in hours and minutes) required to run the entire process manually.
- From the Criticality drop-down list, select the process criticality that appears on the ROI report (High, Medium, or Low).
- (Optional) In the App/System Group Name field, enter the common group name through which the product aggregates processes in the ROI report.
Note: See the tooltips or the User Interface Reference for field descriptions and examples.
- Click Save.
