Directs SQL to retrieve data from an external data source and store that data in a variable (named callBack) that you define.
Note: In CA Process Automation releases before 04.1.00, this method was named ca_pam_getDataFromSQLQuery.
Defines the class name for the installed SQL driver that you are using (for example, com.mysql.jdbc.driver).
Defines the URL of the database application to query as in the following example:
jdbc:mysql://myPC-xp.myCompany.com:CA Portal/<path> or https://<server>:CA Portal/
Defines a user name or login credentials for a predefined user account with sufficient permissions to run the query.
Defines the password that is associated with the specified user name.
Defines a specific SQL query statement or a reference to an SQL query statement. The following code represents a sample SQL query:
"select * from employeedatatable where empName like '%"+ca_pam_getTextFieldValue('Form.empName')+"%'";
Defines a reference to the function object to call after retrieving the data, including its onSuccess and onFailure methods.
When the function retrieves the data, either the onSuccess(result) or onFailure(caught) callBack function runs. The function itself does not return any value.
ca_pam_getSQLData(ca_fd.js.driverName (),ca_fd.js.connectionURL(),ca_fd.js.userName(),ca_fd.js.password(),ca_fd.js.queryEmployeeName(),callBack);
This example queries an external data source and stores the resulting data in the callBack variable.
You can also find this function in the out-of-the-box content in CA Process Automation.
