Retrieves the value of a variable from a CA Process Automation dataset.
Note: In CA Process Automation releases before 04.1.00, this method was named ca_pam_getDataFromDatasetQuery.
Defines a string, expression, or function call that results in an absolute path to a dataset. This parameter includes the Datasets keyword, the library path to a dataset object, and the ValueMap array variable name.
Datasets["/BR412-DATA-FOLDER-20111214/Folder_FORMS_20120328/dataset_forms_demo/My_Dataset55"].MyVal
Defines a reference to the function object to call after retrieving the data, including its onSuccess and onFailure methods.
When the function retrieves the data, either the onSuccess(result) or onFailure(caught) callBack function runs. The function itself does not return any value.
ca_pam_getDatasetData(ca_pam_getTextFieldValue('Form.TxtFieldWithDatasetPath'),callBack)
The example code contains the following information:
ca_pam_setTableData('Form.employeeList',result);
ca_pam_showDataInTable(result,'Form.Results','Dataset results');
