The Audit Trail tab lets you display only object versions that meet one or both of the following search criteria:
For example, if you specify 5 in the Filter field, the search returns any Audit Trail object that has 5 in the Version field or has 5 in the Username field
The object editor appears.
The search fields and Search button appear.
Specifies the numeric or alphanumeric search criteria for the following fields, where the search results include any object versions that contain the specified string.
Specifies date range criteria for searching the Last Updated data.
The search process displays objects meeting the specified search criteria.
