Library Browser › Search the Library Browser
Use the search features to find specific items in the Library Browser. You can then perform actions on multiple related objects in the search results.
- Click the Library tab.
- In the Library Browser folder pane, select the root folder or a specific subfolder.
The product limits your search to objects and folders in the selected folder.
- In the Search field, enter the name of an operator or folder.
- (Optional) Click Advanced Search to base a refined search on any of the following properties:
- Name
- Owner
- Type
- Check-In State
- Creation Date
- Modification Date
- Tags
- Click Search.
The search results appear.
Note: If you search in a folder hierarchy with a content package, the product returns only objects in the current release version of the content package. The product also returns objects that reside in the folder hierarchy but are not in the content package.
- Work with objects and folders in the search results as you would in any other library folder.
- To open an item for editing, double-click it.
- To view a shortcut menu of available commands, right-click a single item.
- To apply an action to multiple objects simultaneously, select the items and then right-click a selected item.
- To begin a new search, take one of the following actions:
- Click Reset.
- Click Basic Search or Advanced Search.
- Clear or modify the criteria that are specified in the search fields.
- Click the x in the Basic Search box.
