You can optionally associate each object version with a release version. The Versions tab uses its displayed associations to filter for those objects and versions that are associated with a string you specify. You can search a specific release version to display a version of interest. Alternatively, you can search for a generic string that returns multiple object versions. The Versions tab supports wildcard searches with or without a wildcard character (*), as the following example shows:
Search String |
Search Results |
5 |
Any object version in which the Version field or the Release Version field contains the character 5.
*5 |
5* |
*5* |
Note: See the tooltips or the User Interface Reference for field descriptions and examples.
The search returns the objects and versions that are associated with the specified string.
