Generating and Using Process Documentation › Generate Process Documentation
You can generate process documentation at any time. For example, use this feature to record the status of a process before you transition it to production.
- Open the process from the Library tab.
- In the Designer tab, click Process Documentation toolbar button.
The Process Documentation Options dialog opens.
- (Optional) Select options to include in the documentation.
- Process Dataset
- Operator Information
- Pre-/Post-Execution Code
- Operator Properties
- Operator Dataset
- Exception Handler (if selected, CA Process Automation generates documentation and an image file for any operators in the Exception Handler)
- Lane Change Handler (if selected, CA Process Automation generates documentation and an image file for any operators in the Lane Change Handler)
- Click OK.
A dialog prompts you whether to open or save the file.
- Click open to view the contents of the Zip file, or click Save to save the Zip file to a location of your choice.
The Zip file contains:
- A PDF file that contains the process documentation.
- The full-size images contained in the process documentation. The PDF contains scaled images, so they may not be legible if the process is very large.
- An XML file that contains the raw data used to generate the documentation in XML format. This file lets you transform the XML into other formats.
