Generating and Using Process Documentation › About Process Documentation
You can generate process definition details and graphics with annotations. The output format is PDF.
Process documentation includes details at the following levels:
- Process-level details
- Operator-level details for each operator used in the process flow
The following list summarizes the details that are generated at each level:
Process documentation generates the following details for a selected process:
- Process image
- Process name
- User-created parameters in the process dataset
- Library path
- Owner
- Process version
- Release
- Checked out by
- Creation date
- Last modified date
- Orchestrator where the process resides
- Process tags
Process documentation generates the following details for each operator that a selected process uses:
- Bitmap of the icon that represents the operator
- User-created parameters in the operator dataset
- Operator name
- Operator description
- Operator type (that is, the operator category)
- Operator parameters
- Exit ports
- Execution Settings
- Pre-execution code
- Post-execution code
- Loop
- Timeout
- Target
