Calendars, Schedules, Tasks, and Triggers › Schedules › Monitor Active Schedules
After you activate a schedule, you can monitor it using the Active Schedules link on the Operations page.
- Click the Operations tab.
- On the Operations page, expand the Links pane.
- Click Active Schedules.
- In the toolbar, select an orchestrator and environment and then click Refresh.
- In the Active Schedules table, double-click a schedule.
The Schedule dialog opens.
- On the Schedule dialog:
- Edit the scheduled items. See Schedule Process and Operator Tasks.
- In the toolbar, click Activate to enable the schedule.
- In the toolbar, click Deactivate to disable the schedule. You can also deactivate a schedule on the Operations page.
Note: Your assigned permissions determine whether you can list, open, or edit a specific schedule object. A content administrator or automation object owner can change permissions on an automation object.
- Click Check In or Save and Close.
