At startup, a process instance can assume one of the following identities:
When configuring runtime security at the process level, consider the following guidelines.
Your Objective: |
Required Configuration: |
Run the process as the caller user. Enforce runtime security rights with the identity of the user who starts the process instance. |
Run the process as owner. Enforce runtime security by running process instances under the identity of the owner, regardless of who starts it. |
Disable validating and enforcing process ownership at runtime. |
Select Disable in the Runtime Security field. This option helps ensure backward compatibility for existing processes. |
