You can add, insert, resize, and remove swim lanes in the Process Designer.
To add a new lane to the right of vertically orientated lanes or to the bottom of horizontally orientated lanes:
Note: Alternately, you can click the Add Lane button on the toolbar.
A new lane is added to the Main Editor panel.
To insert a lane anywhere else on the Main Editor tab:
A new lane is inserted.
A lane is inserted above or below the existing lane based on your selection.
Note: The minimum width of a swim lane is 50 pixels.
You can remove a lane from a process by merging it into an existing lane. When merging a lane, you can merge with a lane either to the left or right of a vertically oriented lane or to above or below a horizontally orientated lane.
To remove a lane from a process
Note: If lanes are oriented horizontally, click Merge Lane Above or Merge Lane Below to merge.
