Library Browser › Working with Objects and Folders › Edit an Object › View or Change General Properties of an Object
You can view the general properties of any library object or process.
- Click the Library tab.
- Select a folder, right-click an object, and then select Properties.
- On the Properties pane, click the General tab.
- View the read-only object properties.
Note: See the tooltips or the User Interface Reference for field descriptions.
- (Optional) Edit the Description field for a checked-out or checked-in object. Click Save to store your changes.
