Library Browser › Working with Objects and Folders › Edit an Object › Specify Tags or Keywords for Objects
The Tags tab lets you assign keywords to organize objects according to any meaningful naming system that your organization recognizes. You and other users can then perform an advanced search for objects or folders that use the tags or keywords.
- Click the Library tab.
- Select a folder, right-click an object, and then select Properties.
- On the Properties pane, click the Tags tab.
- On the Tags tab:
- Click Edit.
- Enter one or more comma-separated text values with no spaces between the list items. For example:
testing,security,Project Code Beta
- Click Save.
