Orchestrators mirror data and configuration information that is stored on the Domain Orchestrator. The mirroring setting specifies how often an Orchestrator checks for changes on the Domain Orchestrator. Changes to the Domain Orchestrator are applied to the Orchestrator on the local host. You can set the mirroring interval for an Orchestrator.
When you select a clustered Orchestrator, the interval you set applies to the mirroring to all active nodes in the cluster. A cluster node can be inactive when other nodes in the cluster are updated. In this case, mirroring occurs for the inactive node when it starts up.
Note: You can upload a JAR file to the Orchestrator Resources folder on the Domain Orchestrator. When you restart the Domain Orchestrator, CA Process Automation deploys the file to the Domain Orchestrator. The Domain Orchestrator mirrors (copies) the file at the configured mirroring interval, after which you restart the other Orchestrators. When the Orchestrators restart, the mirrored file is available for their use.
