Administer Agents › About Agent Communication › Configure Agents to Use Simplified Communication
You can configure agents to use simplified communication.
- Click the Configuration tab and expand Agents on the Configuration Browser palette.
- Select the agent for which to switch communication and click Lock.
- Select the Properties tab for the selected agent.
- Clear the Use Deprecated Communication check box.
- Select the agent and click Unlock.
- Click Yes on the Unsaved Data dialog to save the changes.
The agent creates web socket connections and sends connection details to all Orchestrator nodes. Orchestrators use the persisted web socket connection to send requests or updates to the agent as needed.
