Agents installed from CA Process Automation 4.2 use deprecated communication by default. If you previously switched the communication method to use simplified communication, you can switch agent communication back to deprecated communication.
If you have a firewall-enabled environment, reconfigure the firewall port usage before switching from simplified communication to deprecated communication. The Jetty ports used for simplified communication are the standard 80 and 443 for HTTP and HTTPS, respectively. The tomcat ports used in deprecated communication use 8080 and 8443. For more details about agent ports, see the "Ports Used by an Agent" topic in the Installation Guide.
If the Agents palette displays a CA Process Automation agent as inactive, you can start the agent. See Start an Agent.
The agent terminates the web socket connection. After the web socket connection is terminated, the agent uses deprecated communication.
