During an import, you specify whether to import objects as current. Import objects as current when both of the following statements are true:
Note: You can import a process as current where the targets are expressions that point to variables in a dataset. When you import, you can modify the variables in the dataset to reference production touchpoints.
CA Process Automation requires you to wait until after import to map operator targets to production hosts only if you defined a target as an agent ID, IP address, or host name. In this case, do not import objects as current. Instead, update the targets in the operators after import, then mark the imported version as current.
