Maintaining the Domain › Disable the Catalyst Process Automation Services
The Catalyst Process Automation Services is enabled by default. You can disable it by changing a property value in the OasisConfig.properties file.
- Log in as an administrator to the server where the Domain Orchestrator is installed.
- Stop the Orchestrator.
- Navigate to the following folder:
install_dir/server/c2o/.config
- Open the OasisConfig.properties file.
- Scroll to the UCF embedded connector in the jboss-service.xml section of the OasisConfig.properties file.
- Change the ucf.connector.enabled value to false. For example:
ucf.connector.enabled=false
- Save the file and exit.
- Start the Orchestrator.
More information:
Oasis Configuration Properties File
