Administer Orchestrators › Maintain the Orchestrator Host › Start the Orchestrator
Only administrators with administrator credentials on the server where the Orchestrator is installed can restart the Orchestrator service.
- Using the Administrator credentials, log on to host where the target Orchestrator is installed.
- If you logged in to a Windows host, you can restart the Orchestrator service from the Start menu, the Services window, or the command line. Perform one of the following tasks:
- If you logged in to a UNIX or Linux host, perform the following tasks:
- Change directories to ${PAM_HOME}/server/c2o/. For example, change directories to:
/usr/local/CA/PAM/server/c2o
- Run the c2osvrd.sh script with the start option. That is, run:
./c2osvrd.sh start
Note: After starting the service for the Domain Orchestrator, start CA Process Automation.
More information:
Configure File Trigger Properties at the Domain Level
Configure SNMP Trigger Properties at the Domain Level
Administer Triggers
Configure Mail Trigger Properties at the Domain Level
