Getting Started › Control the Timeout Interval
You can change the product timeout interval. By default, the product automatically logs off after 15 minutes of inactivity.
- Log in as an administrator to the server where the Domain Orchestrator is installed.
- Navigate to the following folder:
install_dir/server/c2o/.config
- install_dir
Defines the path where the Domain Orchestrator is installed.
- Open the OasisConfig.properties file with an editor.
- Use Find to locate the following property:
managementconsole.timeout
- Change the property value.
- Save the file and exit.
- Restart the Orchestrator service:
- Stop the Orchestrator.
- Start the Orchestrator.
More information:
Oasis Configuration Properties File
