Before you integrate a large referenced user store, determine if the store contains more than 10,000 users and groups. The eem.max.search.size default value (10000) is the threshold for how many users and groups CA Embedded Entitlements Manager can accept during transfer. The CA Process Automation default (10000) extends the CA EEM default (2000).
Increase the eem.max.search.size value if the following message appears when you search for available users without defining search criteria:
Maximum search limit exceeded.
To override the default threshold in the OasisConfig.properties file, set the following parameter to a new value:
eem.max.search.size = 10000
If you are integrating a large referenced directory, set the value to more than 20000.
install_dir/server/c2o/.config
Refers to the path where the Domain Orchestrator is installed.
