Administer Orchestrators › Maintain the Orchestrator Host › Quarantine an Orchestrator
You can quarantine any Orchestrator except the Domain Orchestrator. Quarantining isolates an Orchestrator. Operators cannot be executed on a quarantined Orchestrator. You cannot open the library of a quarantined Orchestrator. Therefore, you cannot create or save library objects on a quarantined Orchestrator.
- Click the Configuration tab.
- Right-click the Domain and select Lock.
- Right-click the environment containing the Orchestrator you want to quarantine, and select Lock.
- Expand the Orchestrators node.
- Right-click the Orchestrator you want to quarantine, and select Lock.
- Right-click the Orchestrator again, and select Quarantine.
- Click Save.
- Right-click the Orchestrator, and select Unlock.
- Right-click the locked environment, and select Unlock.
- Right-click the Domain, and select Unlock.
More information:
Remove the Quarantine from an Orchestrator
Delete an Orchestrator Touchpoint
Disable an Orchestrator Touchpoint
