Administer Orchestrators › Update the Hierarchy of an Orchestrator Touchpoint › Add a Touchpoint for an Orchestrator
When you add a standalone Orchestrator to an environment, add a touchpoint to the environment and map it to that Orchestrator. Each Orchestrator must be associated with its own touchpoint.
When you add nodes to create a clustered Orchestrator, the load balancer uses the touchpoint that you defined for the first node. The load balancer determines which node handles a request that targets the touchpoint.
- Click the Configuration tab.
- Right-click the environment at which to add a touchpoint and click Lock.
- Expand the Orchestrators node.
- Right-click the target Orchestrator, select Configure touchpoint at, and click the name of the environment you locked.
- In the Add Orchestrator Touchpoint dialog, enter a name for the new touchpoint and click Add.
- Right-click the environment where you added the touchpoint and select Unlock.
The Unsaved Data dialog prompts you to save changes.
- Click Yes.
A new Orchestrator touchpoint is added to the selected environment.
More information:
Add an Orchestrator to an Environment
