Previous Topic: How to Install Products Using Native SMP/E JCLNext Topic: Run the Installation Jobs for a Tape Installation
Prepare the SMP/E Environment for Tape Installation
For information about the members, see the comments in the JCL.
  1. Customize the macro PANSEDIT with your site-specific information and then copy the macro to your SYSPROC location. Replace the rightmost parameters for each ISREDIT CHANGE command. Each time that you edit an installation member, type PANSEDIT on the command line, and press Enter to replace the defaults with your specifications.
    The macro is ready to customize your yourHLQ.SAMPJCL members.
    Note: The following steps include instructions to execute the PANSEDIT macro each time you open a new SAMPJCL member. To edit all SAMPJCL members simultaneously, read and follow the instructions in the PANEDALL member.
  2. Open the SAMPJCL member PAN1ALL in an edit session and execute the PANSEDIT macro from the command line.
    PAN1ALL is customized.
  3. Submit PAN1ALL.
    This job produces the following results:
  4. Open the SAMPJCL member PAN2CSI in an edit session and execute the PANSEDIT macro from the command line.
    PAN2CSI is customized.
  5. Submit PAN2CSI.
