Installing Your Product from Tape › How to Install Products Using Native SMP/E JCL › Run the Installation Jobs for a Tape Installation
Submit and run these SAMPJCL members in sequence. Do not proceed with any job until the previous job has completed successfully.
- Open the SAMPJCL member PAN3RECT in an edit session and execute the PANSEDIT macro from the command line.
Note: Comment out any unwanted FMIDs.
PAN3RECT is customized.
- Submit the yourHLQ.SAMPJCL member PAN3RECT to receive SMP/E base functions.
CA Panvalet is received and now resides in the global zone.
- Open the SAMPJCL member PAN4APP in an edit session and execute the PANSEDIT macro from the command line.
PAN4APP is customized.
- Submit the yourHLQ.SAMPJCL member PAN4APP to apply SMP/E base functions.
Your product is applied and now resides in the target libraries.
- Open the SAMPJCL member PAN5ACC in an edit session and execute the PANSEDIT macro from the command line.
PAN5ACC is customized.
- Submit the yourHLQ.SAMPJCL member PAN5ACC to accept SMP/E base functions.
Your product is accepted and now resides in the distribution libraries.
Copyright © 2012 CA.
