You can view installation status details of each maintenance package, including a list of SMP/E environments where the package is installed. You can also see the SMP/E environment data sets, and the installation status of the package for each SMP/E environment zone. For example, a maintenance package can be received in the global zone, but applied in a target zone, and accepted in a distribution zone.
Note: The installation status is not available for aggregated maintenance packages, for packages that are uninstallable, and for packages that do not have available SMP/E environments for installation.
Depending on the package status for each zone, you can see available actions for the package. For example, if the package is not received in an SMP/E environment zone, the Install action is available.
The maintenance packages for the release are listed.
The Maintenance Package Details dialog opens to the Installation Status tab. A list of SMP/E environments with package status per zone appears.
Note: Click the Actions drop-down list to start the installation wizard for packages that are not yet installed in at least one SMP/E environment zone, or the accept wizard for packages that are not accepted in at least one SMP/E environment zone. Click Install to More Environments to install the maintenance package in one or more SMP/E environments available for the package.
Copyright © 2012 CA.
