Masking lets you add more than one package (or set of maintenance files) from the same location using a pattern (mask). You can use masking for components, maintenance in USS, and maintenance in data sets. You can use masking for files only, not for directories.
Masking: Use the asterisk symbol (*).
Match on a single character.
Match on any number of characters within a data set name qualifier or any number of characters within a member name or file system name.
Match on any number of characters including any number of qualifiers within a data set name.
You can use as many asterisks as you need in one mask. After you enter the mask, a list of files corresponding to the mask pattern appears.
Note: By default, all files in the list are selected. Verify what files you want to add.
Example 1
The following example displays all PDF files that are located in the /a/update/packages directory:
/a/update/packages/*.pdf
Example 2
The following example displays all files located in the /a/update/packages directory whose names contain p0:
/a/update/packages/*p0*
Example 3
The following example displays all sequential data sets whose name starts with PUBLIC.DATA.PTFS.:
PUBLIC.DATA.PTFS.**
Example 4
The following example displays all members in the PDS/PDSE data set PUBLIC.DATA.PTFLIB whose name starts with RO:
PUBLIC.DATA.PTFLIB(RO*)
Copyright © 2012 CA.
