Sometimes, a product is not currently available from the CA Support Online website. For example, if you are testing a beta version of a product, the version is delivered to you by other means. You can add these types of product packages to CA MSM using the Insert New Product action.
You are prompted to supply information about the product.
The product is added to the software catalog.
The Base Install Packages section appears at the right.
You are prompted to identify the package.
Note: To add several packages from the same location, use masking.
Information about the package is saved in the CA MSM database.
Note: To see the added package, refresh the page.
Copyright © 2012 CA.
