Previous Topic: Prepare the SMP/E Environment for Tape InstallationNext Topic: Apply Maintenance
Run the Installation Jobs for a Tape Installation
Submit and run these SAMPJCL members in sequence. Do not proceed with any job until the previous job has completed successfully.
To run the installation jobs
  1. Submit the yourhlq.SAMPJCL member APT3RECT to receive SMP/E base functions.
    CA PanAPT is received and now resides in the global zone.
  2. Customize and submit the yourhlq.SAMPJCL member APT4APP to APPLY SMP/E base functions.
    Your product is applied and now resides in the target libraries.
  3. Customize and submit the yourhlq.SAMPJCL member APT5ACC to ACCEPT SMP/E base functions.
    Your product is accepted and now resides in the distribution libraries.
Note: We recommend that you check for available maintenance; however, you may find that none is available.
