Installing Your Product from Tape › How to Install Products Using Native SMP/E JCL › Prepare the SMP/E Environment for Tape Installation
The members in this procedure prepare the data sets, initialize the zones, and create the DDDEFs for CA PanAPT. External DDDEF data sets are required. The default is NULLFILE.
Prior to beginning this procedure, confirm whether your product uses UNIX System Services (USS). If it does, establishing a hierarchical file system (HFS) may be required as part of the product installation or required as a feature of the product.
For information about the members, see the comments in the JCL.
To prepare the SMP/E environment for your product
- Customize the macro APTSEDIT with your site-specific information and then copy the macro to your syslib location. Replace the rightmost parameters for each ISREDIT CHANGE macro command. Each time you edit an installation member, type APTSEDIT on the TSO command line, and press Enter to replace the defaults with your specifications.
The macro is ready to customize your hlq.SAMPJCL members.
Note: The following steps include instructions to execute the APTSEDIT macro each time you open a new SAMPJCL member. To edit all SAMPJCL members simultaneously, read and follow the instructions in the APTEDALL member.
- Open the SAMPJCL member APT1ALL in an edit session and execute the APTSEDIT macro from the command line.
APT1ALL is customized.
- Submit APT1ALL.
This job produces the following results:
- The target and distribution data sets for CA PanAPT are created.
- Unique SMPLTS, SMPMTS, SMPSCDS, and SMPSTS data sets for this target zone are created.
- Open the SAMPJCL member APT2CSI in an edit session and execute the APTSEDIT macro from the command line.
APT2CSI is customized.
- Submit APT2CSI.
- The CSI data set is defined.
- The SMPPTS and SMPLOG data sets are allocated.
- The global, target, and distribution zones are initialized.
- The DDDEF entries for your product are created.
- The DDDEFs for the required SMP/E data sets are created.
Copyright © 2010 CA.
