A modified copy of the IBM sample ISPF/PDF Primary Option Menu panel is distributed with CA PanAPT on the CAI.CABYPENU data set as member APIPPRIM. It has been modified to place the CA PanAPT option on the display definition and on the corresponding SELECT statement in the PROC section. The modifications have been changed with this release to activate the new User Identification Facility (UIF). A sample SELECT statement for CA PanAPT without UIF has been provided as a comment line. APIPPRIM has been provided with the assumption that you will want to use the UIF feature.
Examine these modifications and make the same modifications to your Primary Option Menu panel (ISR@PRIM). Or, use APIPPRIM as distributed after renaming it ISR@PRIM and after reviewing it for compatibility with your system.
You can make three modifications to your Primary Option Menu panel:
A sample ISPF/PDF Primary Option Menu panel for CA PanAPT with both the UIF (Option A) and the UIF administrator's function (Option U) visible is shown next. Notice the line below Option A. An input field is associated with the selection of this option. Be sure to include this line if you want to use CA PanAPT with the UIF feature.
‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑ ISPF/PDF PRIMARY OPTION MENU ‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑‑ OPTION ===> USERID ‑ BUTRO02 0 ISPF PARMS ‑ Specify terminal and user parameters TIME ‑ 17:29 1 BROWSE ‑ Display source data or output listings TERMINAL ‑ 3278 2 EDIT ‑ Create or change source data PF KEYS ‑ 24 3 UTILITIES ‑ Perform utility functions 4 FOREGROUND ‑ Invoke language processors in foreground 5 BATCH ‑ Submit job for language processing 6 COMMAND ‑ Enter TSO command or CLIST 7 DIALOG TEST ‑ Perform dialog testing 8 LM UTILITIES ‑ Perform library management utility functions A CA PanAPT ‑ Development and Production Turnover System: For UIF, Enter CA PanAPT Logon System‑ID or * for MSL => ________ U CA PanAPT/UIF ‑ APT User Identification Facility, System‑ID setup C CHANGES ‑ Display summary of changes for this release T TUTORIAL ‑ Display information about ISPF/PDF X EXIT ‑ Terminate ISPF using log and list defaults Enter END command to terminate ISPF.
You can invoke CA PanAPT with and without the UIF
Copyright © 2010 CA.
