Create a TSO logon procedure to allocate the necessary CA PanAPT software libraries. Concatenate these data sets with the corresponding IBM ISPF/PDF data sets.
To create a TSO logon procedure
As an alternative, place these libraries in the link list.
Ensure that the CA PanAPT PDS libraries have a block size that is equal to or larger than all of the other data sets in each concatenation, or unpredictable results occur.
The SYSOUT DD is required by some sort programs. Without it, the sort might pass back a non‑zero return code, causing online reports to fail.
The following is a sample TSO logon procedure:
Authorize several TSO user IDs to use this logon procedure so you can see the effects of CA PanAPT security authorization.
//STEPNAME EXEC PGM=IKJEFTO1,PARM='PROFILE',DYNAMNBR=25 //* //* Note: This example LOGON procedure assumes that a CLIST //* named PROFILE exists in the SYSPROC concatenation, //* and that it will allocate the user's ISPPROF data set. //* This is done via the PARM='PROFILE' on the EXEC //* statement. If you do not want to follow this //* procedure, remove the PARM='PROFILE' from the EXEC. //* //STEPLIB DD DISP=SHR,DSN=CAI.CABYLOAD // DD DISP=SHR,DSN=SYS1.COB2LIB // DD DISP=SHR,DSN=ISR.V2R3MO.ISRLOAD // DD DISP=SHR,DSN=ISP.V2R3MO.ISPLOAD //ISPLLIB DD DISP=SHR,DSN=CAI.CABYLOAD // DD DISP=SHR,DSN=SYS1.COB2LIB // DD DISP=SHR,DSN=ISR.V2R3MO.ISRLOAD // DD DISP=SHR,DSN=ISP.V2R3MO.ISPLOAD //ISPPLIB DD DISP=SHR,DSN=CAI.CABYPENU // DD DISP=SHR,DSN=ISR.V2R3MO.ISPPLIB // DD DISP=SHR,DSN=ISP.V2R3MO.ISPPLIB //ISPMLIB DD DISP=SHR,DSN=CAI.CABYMSG0 // DD DISP=SHR,DSN=ISR.V2R3MO.ISRMLIB // DD DISP=SHR,DSN=ISP.V2R3MO.ISPMLIB //ISPSLIB DD DISP=SHR,DSN=CAI.CABYSKL0 // DD DISP=SHR,DSN=ISR.V2R3MO.ISRSLIB // DD DISP=SHR,DSN=ISP.V2R3MO.ISPSLIB //ISPTLIB DD DISP=SHR,DSN=CAI.CABYTBL0 // DD DISP=SHR,DSN=ISR.V2R3MO.ISRTLIB // DD DISP=SHR,DSN=ISR.V2R3MO.ISPTLIB //SYSPROC DD DISP=SHR,DSN=CAI.CABYCLS0 // DD DISP=SHR,DSN=ISR.V2R3MO.ISRCLIB //APTSIDTB DD DISP=SHR,DSN=CAI.APTSIDTB //SYSPRINT DD TERM=TS //SYSOUT DD TERM=TS //SYSIN DD TERM=TS //* //* If you are not using the UIF function and you are invoking //* CA PanAPT without invoking the APT CLIST, you must allocate //* the APTDB and CABYDATA data sets prior to executing //* PGM(APCS1000) from the primary option menu. //* //* APTDB DD DISP=SHR,DSN=CAI.APTDB //* APTMODEL DD DISP=SHR,DSN=CAI.CABYDATA
Copyright © 2010 CA.
