Previous Topic: External Security SetupNext Topic: Installing Your Product Using CA MSM
Storage Requirements
The following table shows a list of the storage requirements for the various components of the CA PanAPT product:
Product Component
Delivered software libraries
60 cylinders of 3380 space
Control and processing files
15 cylinders of 3380 space
TSO address space
2048 KB
Maximum batch region
4096 KB
The installation job creates two CA PanAPT VSAM files in addition to the three CA PanAPT VSAM files that are on the installation tape. They are:
The installation job can optionally create another CA PanAPT VSAM file (the Startup History File) that has a space requirement of CYL,(3,1).
