CA PanAPT issues external security calls for just about every function and action related to CA PanAPT functionality. CA PanAPT uses the CA Standard Security Facility (CAISSF), which is a standardized security interface to CA ACF2, CA Top Secret for z/OS, and RACF. The CA PanAPT User Identification Facility (UIF) also interfaces with external security.
All security rules are in DSN format so that the rules built by CA PanAPT are the same regardless of the security package you are running.
To use the external security interface
If your security package requires access rules, you must update your security system to allow access for the following security checks:
PANAPTU.PANAPT
PANAPTU.PANSYSID.system-id
PANAPTU.PANUIF
PANAPTF.system-id.xxxxxxxx.xxxxxxxx.xxxxxxx
See CA ACF2 Example, which allows access to all users and all activities.
Copyright © 2010 CA.
