Previous Topic: Compatibility with CA RoscoeNext Topic: Compatibility with FDR
Compatibility with CA Jobtrac
If you use CA PMO with CA PMO, you must specify the parameter DESIZE=76 (the default), even if CA PMO is not managing any CA PMO libraries. Directory entries for libraries managed by CA PMO are 76 bytes instead of the standard 64 bytes.
