Previous Topic: Compatibility with CA PanexecNext Topic: Compatibility with CA 7
Compatibility with eTrust CA Top Secret
This section is important if you use both CA PMO and eTrust CA Top Secret (unless you use CA PDSMAN in addition to these two products):
Specify TOPSECRT=YES in your parameter data set if you plan to reinitialize eTrust CA Top Secret while CA PMO is running. Before eTrust CA Top Secret reinitializes, it removes its old SVC 21 intercept. If CA PMO is active during the eTrust CA Top Secret initialization, CA PMO SVC 21 intercept is effectively removed. This may cause a system abend 215 or 0C4 in PMO/XSYS or in a user address space. When you specify TOPSECRT=YES, CA PMO automatically stops and restarts itself (installing its SVC 21 in the process) when you reinitialize eTrust CA Top Secret.
The following illustration shows the correct order of the SVC 21 intercepts:
pmsvc12
Notes:
  1. CA PMO does not reuse the ECSA it needs when it is restarted. If ECSA usage at your site is critical, avoid unnecessary eTrust CA Top Secret reinitializations.
  2. Some eTrust CA Top Secret functions, such as enabling PDS member level protection using the MODIFY TSS,PDSPROT(ON) command, displace the CA PMO SVC18 intercept as well as the SVC21 intercept.
