Previous Topic: Changing the Status of the CA PMO/DFDSS InterfaceNext Topic: Excluding a Private Library from Management
Excluding a LNKLST Library from Management
The EXCLLNK command excludes LNKLST libraries from CA PMO management.
Format
The EXCLLNK command has the following syntax:
F PMO {,EXCLLNK=data set name}
      {,EXCLLNK=ALL}
This command has the following operands:
PMO
The CA PMO keyword.
EXCLLNK
You specify this operand as follows:
Tells CA PMO to exclude data set name from management.
EXCLLNK=ALL
Tells CA PMO to exclude all LNKLST libraries from management.
Messages
After successfully executing this command, CA PMO responds:
PMO338I EXCLLNK SUCCESSFUL FOR DSN=data set name LNKLST=linklistname
CA PMO continues to accumulate statistics for the excluded library (or libraries) on the PMOMON D4 display. CA PMO does not reset the statistics that it obtained while managing the library (or libraries).
If the library specified with this command has already been excluded from management, CA PMO responds:
PMO334I PMO HAS PREVIOUSLY EXCLUDED DSN=data set name
If you issued the command F PMO,EXCLLNK=ALL, and all LNKLST libraries are already excluded from management, CA PMO responds:
PMO336I ALL LNKLST LIBRARIES CURRENTLY EXCLUDED
If the library specified on the F PMO,EXCLLNK command is not in the LNKLST concatenation, CA PMO responds:
PMO332I PMO UNABLE TO EXCLLNK DSN=data set name
If you receive this message, check the D4 monitor display for the correct names of LNKLST libraries.
Note: You can include any excluded library with the F PMO,INCLLNK command.
