The DFDSS command changes the status of the CA PMO/DFDSS interface.
Note: This command has no effect if the CA PMO/DFDSS interface has not been installed.
The DFDSS command has the following syntax:
F PMO,DFDSS=interface option
This command has the following operands:
The CA PMO keyword.
DFDSS=interface option, where interface option can have one of the following values:
Tells CA PMO to enable the CA PMO/DFDSS interface so that updates will be communicated to CA PMO.
Tells CA PMO to disable the CA PMO/DFDSS interface so that updates will not be communicated to CA PMO.
Copyright © 2011 CA.
