Previous Topic: P CommandNext Topic: Requesting Management Information About a Library
C Command
This command cancels CA PMO. It stops CA PMO and prevents it from reusing its ECSA code and data areas the next time it is started. ECSA is not freed.
Format
This stop command has the following format:
C PMO
This stop command has the following operands:
PMO
The CA PMO started task name.
Messages
When you issue this command, CA PMO responds with the following message:
PMO099I ESTAE ENTERED, PMO QUIESCING
