This parameter determines whether CA PMO will coexist with CA Roscoe. For more information on compatibility issues, see the chapter "Compatibility with Other Products."
The ROSCOE parameter has the following syntax:
ROSCOE=coexist option
where coexist option has of following values:
Indicates that CA PMO will not coexist with CA Roscoe. Specify this option if you do not have CA Roscoe.
Specify ROSCOE=YES if both CA PMO and CA Roscoe reside on your system. This ensures compatibility between the products.
Default: ROSCOE=NO
Copyright © 2011 CA.
