The maximum number of private libraries that can be added for management by issuing the F PMO,INCLPRVT command or by automatic management. CA PMO uses this number to determine how much storage to keep for its library statistics. For each library, 224 bytes of storage is obtained in ECSA.
The NUMADDED parameter has the following syntax:
NUMADDED=nnn
The NUMADDED parameter requires the following value:
Designates the maximum number of private libraries that can be added once CA PMO is active.
Default: NUMADDED=400 if CA PMO is managing your private libraries automatically
NUMADDED=30 on all systems, if you specified the parameter EXCLAUTO=*.
Note: Specifying NUMADDED=0 is equivalent to specifying EXCLAUTO=*.
Copyright © 2011 CA.
