Previous Topic: EXCPCOST ParameterNext Topic: FDR Parameter
EXCPCPU Parameter
The CPU time per EXCP.
Format
The EXCPCPU parameter has the following syntax:
EXCPCPU=microseconds per EXCP
The EXCPCPU parameter requires the following value:
The number of CPU microseconds per EXCP. CA PMO uses this value and the value of the SVCCPU parameter to calculate CPU time savings.
The default value is 39 microseconds for an IBM 9672-R66 processor. To find the appropriate time for another configuration, use the following formula:
microseconds per EXCP = 39 x (5036.2 / CPU service units per sec)
You can find CPU service units/sec (SU/SEC) for IBM processors on the IBM web site.
Default: EXCPCPU=39 (for an IBM 9672-R66 processor)
