Previous Topic: EXCLREPT ParameterNext Topic: EXCPCPU Parameter
EXCPCOST Parameter
The monetary cost of 1000 EXCPs.
Format
The EXCPCOST parameter has the following syntax:
EXCPCOST=monetary cost
The EXCPCOST parameter requires the following value:
monetary cost
The monetary cost of 1000 EXCPs in the unit set by the MONEYSYM parameter. CA PMO uses this value to calculate the money it saves by reducing EXCPs.
Note: Be sure that the value you specify for EXCPCOST is consistent with the monetary symbol that you specify as a value for the MONEYSYM parameter.
Default: None
