Previous Topic: D9: Candidate Private Library Searches – DetailedNext Topic: Executing PMOMON as a Batch Job
D10: Library Same-System and Cross-System Updates
The D10 display shows how many updates were performed and what percentage of those were cross-system updates from PMO/XSYS or PMO/XCF.
By default, the D10 display lists all LNKLST and private libraries with at least one update. To restrict this list to a set of particular libraries, you can type the following command from any other monitor display:
D10-library name
The library name can be the beginning of a library name or the entire name, up to 44 characters.
Commands you can issue from the command line of the D10 display include:
LB-library name
Restricts the list of libraries on the display to the library name or partial name you specify.
LNK
Displays LNKLST libraries with updates.
PVT
Displays private libraries with updates.
SUM
Displays only the totals for library updates.
The following screen illustrates a sample D10 display:
PMO 4.4 ( Active ) Sys=IPOX 13NOV10:09:10:50 PMO Active Time= 5.500 hrs D10 Library Same-System and Cross-System Updates
Library %XSYS Member %XSYS Library Name Volser Updates &XCF Updates &XCF LNKLST Total for Set IPL 37 16 88 70 SYS2.USER.LINKLIB MVSWXA 25 0 0 0 ATMQA.LOAD MVSWXA 12 50 88 70 Managed Private Library Total 18 67 34 71 ACCUMAX.DB2DSTG2.LOAD TSU035 4 100 4 100 ASX.ASX015.DISTPLIB MVS963 1 0 0 0 ASX.ASX015.TESTLLIB MVS963 10 50 20 50 ASX.ASX015.TESTLOAD MVS963 3 100 10 100 Previously Managed Libraries 0 0 0 0 Excluded-PDS Updates Not Sent 367 N/A 150 N/A Excluded-PDS Updates Not Received 874 100 589 100
XCF Statistics Messages Sent 59 Updates Sent 73 Messages Received 82 Updates Received 104
Column Headings
The column headings on the D10 display are described in the following list:
Library Name
The name of the library.
Volser
The serial number of the volume that contains the library.
Library Updates
The number of updates to the library.
%XSYS &XCF
The percentage of updates that were cross-system updates.
Member Updates
The number of updates to members of the library.
%XSYS &XCF
The percentage of member updates that were cross-system updates.
Row Headings
The row headings on the D10 display are described in the following:
LNKLST Library Total
The total number of updates to LNKLST libraries and what percentage were cross-system updates.
The total number of updates to managed private libraries and what percentage were cross-system updates.
The total number of updates to libraries that are excluded from CA PMO management and that were not sent cross-system. This row will appear only if all of the following conditions are true:
The parameter XSYSCOMM=PMO is specified.
Libraries were excluded using the EXCLAUTO or INCLAUTO parameters.
PMO/XSYS is active on this system.
These numbers will be sent cross-system and displayed as "Excluded-PDS Updates Not Received."
The total number of updates to libraries that are excluded from CA PMO management that were not sent to this system. At least one system in the complex meets the criteria under "Excluded-PDS Updates Not Sent."
The total number of updates to private libraries that were managed by CA PMO and were stopped (manually or through automatic library management).
Messages Sent
The total number of update messages that have been sent to other systems in the sysplex using PMO/XCF.
Updates Sent
The total number of library and member updates that have been sent to other systems using the PMO/XCF messages.
Messages Received
The total number of update messages that have been received from other systems in the sysplex using PMO/XCF.
Updates Received
The total number of library and member updates that have been received from other sytems using the PMO/XCF messages.
